[SOLVED] Ds1307 and 18f452 Error with external batery backup
buddhikaneel
Member level 1
Hi. my dear firends.
I have made clock using DS1307 and 18f452. crystal also connected. SDL, SDA also connected well and pull up it using 10k Resistors. if i ground Battery pin clock is working well. Then i attach external battery to it (+) and (-) was grounded. then it's not working correctly it displays "@5 @5 @5" like wrong. Then i was connected LED bulb between battery pin and ground pin parallel. Then it was working correct. What could be the wrong with me..
Thank you...
Can you post schematic of your design?
What is the voltage of the battery, you are attempting to utilize?
What are the current Configuration Bit settings?
BigDog
I attach Sehematic and codeing togerther.
  • Ds1307.rar
i found wrong i did. i attached wrong power for RTC. Now i set 3.v battery. it is working well. thank for help....
