Doubts in Ansoft Tool Usage
comedykhan
Newbie level 3
Hello.....
am a UG student.... am doing project Antenna field..... Am using Student version of Ansoft 2.2 . I want to know the procedure to view near and far field patterns after performing Analysis of the design... I have checked the "Generate current file" checkbox while choosing "Frequency Sweep"... but still the "Near field", "far field" options are not enabled...
Added after 6 minutes:
it is urgent for me.... pls help.... is it not available in student version??? or is there any special procedure????
In your project tree in the left column, right click "Radiation", then "Insert Far Field Setup", then "Infinite Sphere", default options should work fine.
Repeat for Near Field Setup with line or sphere...
