Does HSPICE2004.09 include AWAVES for linux?
byron
Member level 3
Member level 3
awaves linux
During the installation and configuration I noticed there is awaves in the list, and there is a script file "awaves" in the /bin directory after configuration. But it shows "command not found, no awaves in /linux/bin" if runing awaves.
awaves
I don't think so.
error: avanwave is not supported on linux now
for i know, cosmos scope for linux.
error: avanwave is not supported on linux now.
mariaR said:
I don't think so.
Which one? The awaves in the configuration list or the awaves command is not found in the /linux/bin.
avanwave
Under Linux, C0sm0ssc0pe is used for viewing graphics.
@waves used for other platform.
please set environment variable display awaves
SpiceExplorer is another alternative
there is no avanwaves for linux
awaves alternative linux
Avanwaves has not been updated by Synopsys, which will be replaced by Cscope Waveviewer tools.
wine awave linux
There is no awaves in any Linux system. Personally, I will recommand sandwork's spice_explorer. Please reference there web site
**broken link removed**.
It's fast and powerful.
hspice/sparcos5/awaves: command not found
no avanwave for linux !
hspice shlib_path
Hi
Notice to all Edaboard members Guru!!
What did you think about to develope a customized hspice viewer for linux in this forum.
I have readed some times ago about some tries too.
tnx
awaves synopsys
it's a good idea. But how can we do it ?
running awaves on linux
byron said:
mariaR said:
I don't think so.
awaves in linux is shell command
, but I don't like cosMOsscope , awaves is easy use .
cosMOsScope is poor tool ...
setenv installdir hspice-x2005.09-sp1
unsetenv GALAXYHOME
if (! $?ARCH) then
set ARCH = `$installdir/bin/get_arch `
endif
if ($ARCH == unknown) then
cat << FUBAR
Error: Unable to determine Operating System or Architecture!
Please execute the following command: uname -a
Call Synopsys Customer Service and report the results immediately.
FUBAR
exit 1
else if(($ARCH != hp32) && ($ARCH != sparcOS5) && ($ARCH != rs6000)) then
cat << FUBAR
Error: AvanWave is not supported on $ARCH now.
FUBAR
exit 1
endif
if ( $?LD_LIBRARY_PATH ) then
if ( "$LD_LIBRARY_PATH" !~ *"$installdir/$ARCH"* ) then
setenv LD_LIBRARY_PATH $installdir/"$ARCH":$LD_LIBRARY_PATH
endif
else
setenv LD_LIBRARY_PATH $installdir/$ARCH
endif
if ( $?LIBPATH ) then
if ( "$LIBPATH" !~ *"$installdir/$ARCH"* ) then
setenv LIBPATH $installdir/"$ARCH":$LIBPATH
endif
else
setenv LIBPATH $installdir/$ARCH
endif
if ( $?SHLIB_PATH ) then
if ( "$SHLIB_PATH" !~ *"$installdir/$ARCH"* ) then
setenv SHLIB_PATH $installdir/"$ARCH":$SHLIB_PATH
#if (! $?DISPLAY) setenv DISPLAY `hostname`:0
if ( ! $?DISPLAY ) then
echo -n " o Please set environment variable DISPLAY"
exit 1
endif
if ( `echo $DISPLAY | egrep -c '^:$'` == 1 ) setenv DISPLAY `hostname`:0.0
if ( `echo $DISPLAY | egrep -c '^:'` == 1 ) setenv DISPLAY `hostname`$DISPLAY
if ( `echo $DISPLAY | egrep -c ':'` == 0 ) setenv DISPLAY ${DISPLAY}:0.0
if (! $?ExecCmd) then
set ExecCmd = "$installdir/$ARCH/awaves -laf motif"
endif
echo
echo o Running $ExecCmd on $DISPLAY
echo
$ExecCmd $* &
awaves on linux
My platform is linux ,and i find a dirctory named "linux" under hspice intall directory,
But i can't find any command named "awaves" under "linux" directory
awave for linux
sorry , I am wrong , synopsys only support cosmosScope on Linux ,
awave on windows/Unix .. cosmosScope also have windows version
, maybe you can try use "wine + windows awaves" under linux
but I have interesting is hspice new model "level66"
have anyone already use level66 spice model ?
