zeeba
Junior Member level 2
Hi everybody
I want to Read two analogue inputs from two LDRs and display them on the LCD.
I wrote a code but the problem is :
the readings on the LCD are almost the same even if there is a difference between the lighting on the LDRs.
I used the volt meter to measure, there is a difference in volts that's mean there is a difference between the lighting on the LDRs but the readings on the LCD almost the same.
It suppose to be two lines: line1 to read from LDR1 and line2 to read from LDR2 but as I said the two readings are the same
-BTW I'm using assembly and PIC16F876A-
