I'm not trying to flame here, and I agree that C++ is overkill for a PIC, but you would change you mind about C++ after working with 10 other programmers on the same executable. Granted, embedded firmware projects are relatively small and it's rare when there are more than 2 programmers working on the code for the same microcontroller. However, in the world of software large projects are not uncommon, and integration of large project in C++ is a lot easier than in C.btbass said:Lets face it, C++ is the biggest, corrupted, name mangled, convoluted pile of indecypheral crap that ever pretended to be a programming language.
// class template Factory
// Implements a generic object factory
template
class AbstractProduct,
typename IdentifierType,
typename ProductCreator = AbstractProduct* (*)(),
template<typename, class>
class FactoryErrorPolicy = DefaultFactoryError
class Factory
: public FactoryErrorPolicy<IdentifierType, AbstractProduct>
public:
bool Register(const IdentifierType& id, ProductCreator creator)
return associations_.insert(
IdToProductMap::value_type(id, creator)).second;
bool Unregister(const IdentifierType& id)
return associations_.erase(id) == 1;
AbstractProduct* CreateObject(const IdentifierType& id)
typename IdToProductMap::iterator i = associations_.find(id);
if (i != associations_.end())
return (i->second)();
return OnUnknownType(id);
private:
typedef AssocVector<IdentifierType, ProductCreator> IdToProductMap;
IdToProductMap associations_;
