tOngEh
Junior Member level 2
Diode question
HI all, I met a problem in my simple circuit which i cant solve for the past 2weeks.
Attached in the circuit schematic and Output voltage. I wish to see the modulated carrier sitting the Squarewave with diode turn on/off effect. However, i cant justified the ringing output. Pls help. Thank you!
RF(1.5GHz sinwave carrier ) and DC(4MHz squarewave) are injected into a bias tee consisting a LC. Upon summing, the resultant signal is feed into a diode followed by a LC(passing the 1.5GHz carrier) to generate a ASK signal.
Thank you!
Thank you!
