Differences between implementation of full-chip and block
designer_ec
Member level 4
Full-chip and block
Please anybody clarify below doubt clearly.
What differences found during implementation of full chip & block level chip.
Thanks in advance.
Re: Full-chip and block
Block-Level Design is nothing but Flat Design which is without a hierarchy i,e, without sub modules or blocks.
Top-Level or Full chip is one which is a integration of modules or blocks. This obviously will consume more run time and memory consequently more area and power.
Thanks,
KAPIL B
Thanks kapil,but I want that during floorplan,placement,cts (clock tree build),Routing,extraction like this at each stage how we implement for full chip & block level.I.e what are the differences (according to implementation) find for fullchip & block.
Regarding this if anybody had good material please upload here.
can u be more specific
I am not asking about flat level design & hierarchy level design.I am asking about differences between implimentation of full chip and block.Because I worked for block.But I want to know full details about each stage implementation of full chip.
fullchip verification and block lever is different!
go through jupiterxt lab guide if u want to know more abt full-chip and go through Astro for block-level.
Hi Kapil,
Please upload jupiterxt lab guide & astro meterila here.
hi,
which P & R tool do u use.
Thanks,
KAPIL B
Hi Kapil,
I am working with magma blastfusion P & R tool
Then go through Blast Plan Pro Ducumentation. U will how hierarachial design is implemented in Blast-Plan Pro. Go through the flow of Blast Plan pro in Molten. U will get better picture. Hope this helps.
you may divide your design into several module according to different function,
we can treated one function module as a block, and all function module as Full-Chip
