giggs11
Member level 3
timingcheck instance
Hi guys,
I'd like to know about HDL simulation process. How does it work...? I usually use a FPGA design entry tool like QuartusII for HDL simulation but am also aware of tools like VCS that can do the job.
So, my question is....does the HDL simulator map the design to a certain library before functional simulation...? For instance, in an FPGA based HDL Simulator....does the tool map the design to the FPGA cell library before simulation...? because, if it doesn't map to a cell-library, how is it able to deliver the correct timing dependent functionality sim. results..?
I'm also curious of gate-level simulation. I know that after synthesis using Synopsys DC...we target the design to P&R but is there a way to verify the functionality of the synthesized design before P&R...Is this where VCS comes in and hence the requirement of a VHDL library for the step...?
Thanks.
Hi guys,
Thanks.
