adix
Junior Member level 2
Hi all,
I have a problem when I try to run ocean simulations with my technology. The problem is that in schematics I have to put the size of the transistor without adding "u" or "n" (indicating micro or nano). If I add u or n, it will show an error. E.g. if I want a mos with length 400n I have to put just 0.4. When I run the spectre simulation in ADE it works perfectly. When I run the same simulation in ocean it shows errors about the size of the transistors. I tried to open the netlist and indeed the length of the transistor is 0.4 (meters!!!) Any idea on how to solve the issue? Thanks in advance...
