Device parameters in Hspice
suhas_shiv
Full Member level 2
What is the command to see the device(transistor) parameters in Hspice? In Spectre, you do a print device conditionsand click on the particularMOS to see the parameters. In Hspice what is the equivalent command?
Thanks
.probe gm = par('gmo(m1)')
.probe gds = par('gdso(m1)')
...and similar statements in the netlist.
Consult the HSPICE reference manual for a full listing of device parameters you can access.
run a
.op
watch the log file, you can find cgs, vtsat,,.... for every device.
