eda4you
Full Member level 5
s0c enc0unter
Hallo!
I've following task in cadence: I want to find a design flow using tools which are actuall (and will be supported in future). But I've only lx86 tools since I've no sun. Therefore I can't make use of scripts for silicon ensemble since it isn't supported in linux (or I'm wrong). So I've find other design flows but there are so many tools!! Also I've heard for instance that the pks tool won't be supported in future and so on. Hence I'm very confused. But I need a flow for my mixed signal designs.
Therefore, which tool should I use?
synth: buildgates (is there a more efficient and better synth tool in cadence?)
place&route: pks (no support in future),? which linux tool?
Route: nanoroute, my foundary also support ic craftsman (but a friend told me that it is not to be recommended
what are the other tools for: encounter, or the others in the soc or spr packages?
Hallo!
