MOS transistors are not discrete components, so you cant look at datasheet or data book for them. They are integrated ones. If you have the schematic, you can know which is NMOS and which is PMOS. They have different symbols. Source of NMOS are usually connected closer to the GND side while those of PMOS are usually connected closer to VCC or VDD side.You look at the part number and look it up in a data book or datasheet and then determine.
Tahmid.
amraldo said:PMOS and NMOS are not available as discrete components.
amraldo said:sounds interesting. first time 2 see it. these discrete ones r only used in power electronics?
Amr
