I wanna measure delay of a ripple carry adder from modelsim simulation.program works fine.I can see the output waveforms also.but i can't find any delay between inputs and output even with zoom view also.i have attached my output screenshot
first you need to generate the SDF file, it is a very complicated process.
I suggest you take the gate level design and quantify delays of each gate (like delay of INV1X=1 and model delays of larger gates as multiple of these using the formula d=p+g*h) and calculate the approximate delay.
