Chinmaye
Full Member level 3
I have designed a fully differential 2 stage opamp with resistive CMFB circuit, to be used in switched capacitor amplifier. I see that, during the sampling phase, most of the times, the common mode output of the amplifier is moving towards the rails in the transient analysis while it is expected to be at 0V. Adding decoupling capacitors across the resistive CMFB helps but i still do not understand how the decoupling capacitors are able to maintain a common mode output of 0V. Can someone help me understand this?
