decalaring many constant in 1 name...
energy_baz
Junior Member level 1
hi,
I have question on how to use array to declare my constant values. I want to use all the constant value in generic map. So, should I declare all the constant in generic..? As example :
constant ( z : integer := 3);
type a is array (0 to z-1) of integer;
constant b : a := (3,5,7)
I need to use all these value in generic map..thanks in advance...
you need to declare the type in a package if you want to use that type as a generic.
No you cant, which is one of the problems - you need to then declare the constant in the package.
But the code you posted you dont need the constant.
package type_pkg is
  type a_t is array(integer range <>) of integer;
end package type_pkg.
entity some_ent is
  generic (
    a : a_t(0 to 2); --you dont need Z anymore, because you can declare the size of the array here
true, but the type can be defined
sorry posts crossed each other
how about the constant value 5,6,7? Do i have to declare it in the package as well? I need to include all these value later in generate statement..which it will be call in my generic map..
no, you can just declare the constant when you need it, or just define it on the generic map:
generic map (
a => (3,5,7),
