STSCBE
Member level 2
Hi all,
Im using PIC12F683 controller and MPLABX IDE with internal oscillator 4MHZ. My application contains Reading adc voltage, Frequency Counter(capture), 2 Relay outputs and status LED.
i want to debug my application by PICkit3. after upload the codes it shows the error "Debug Header is required" then i change the default debug header in project properties. then as per pickit3 manual i disabled the WDT and PWRTE bit.
that says,
what to do?
Thanks.
that says,
The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding. The most common causes for this failure are oscillator and/or PGC/PGD settings.
what to do?
Thanks.
