mr_mosfet
Newbie level 3
Hopefully this is posted in the right area. I'm trying to model the current of the device which is captured by one of the last lines of this code:
(I(p,n) <+ ddt(polar)
When I implement the code as above I get a flat line for the current (brown curve in the first pic named "ddt_polar"). However I think it should be nonzero in places. I ran the same simulation with the current set to:
I(p,n) <+ polar;
and got the curve as seen in the second pic named "polar". Clearly the polar variable is changing so ddt(polar) should give me a nonzero current but its not. Why is this so?
Thank you.
// VerilogA for tech_support3, test, veriloga
`include "constants.vams"
`include "disciplines.vams"
`define M_PI 3.14159
module test(p,n);
inout p,n;
electrical p,n;
real v_prev;
real v_present;
real v_c_pos;//positive coercive voltage
real v_c_neg;//negative coercive voltage
real v_tp_pos;//positive turning point
real v_tp_neg;//negative turning point
real polar;
real polar_r;
real polar_tp_pos;
real polar_tp_neg;
real polar_temp;
analog function real f;
real v; real v_c;//v_c is coercive voltagle
input v; input v_c;
f = (2/`M_PI)*atan((v-v_c));
endfunction
analog begin
@(initial_step) begin
v_prev = 0;
v_present = 0;
v_c_pos = 5;
v_c_neg = -5;
v_tp_pos = 5;
v_tp_neg = -5;
polar = 0;
polar_r = 1;
polar_tp_pos = 0;//positive coercive voltage
polar_tp_neg = 0;//negative coercive voltage absolute value
end
if ((v_present > v_prev) && (v_present > 0)) begin
polar_temp = polar_tp_neg + 0.5*polar_r*(1 + f(v_present, v_c_pos))*(1 + f(-1*v_tp_neg, -1*v_c_neg));
if(polar_temp > polar)
polar = polar_temp;
if (v_present > v_tp_pos)
v_tp_pos = v_present;
polar_tp_pos = polar_tp_neg + 0.5*polar_r*(1 + f(v_present, v_c_pos))*(1 + f(-1*v_tp_neg, -1*v_c_neg));
end
if ((v_present < v_prev) && (v_present < 0)) begin
polar_temp = polar_tp_pos - 0.5*polar_r*(1 + f(v_tp_pos, v_c_pos))*(1 + f(-1*v_present, -1*v_c_neg));
if(polar_temp < polar)
polar = polar_temp;
if (v_present < v_tp_neg)
v_tp_neg = v_present;
polar_tp_neg = polar_tp_pos - 0.5*polar_r*(1+ f(v_tp_pos, v_c_pos))*(1 + f(-1*v_present, -1*v_c_neg));
end
v_prev = v_present;
v_present = V(p,n);
I(p,n) <+ ddt(polar);//current equation currently not working
end
endmodule
I(p,n) <+ polar;
Thank you.
