Assuming you are using Xilinx FPGA, an IDDR primitive can be used. It has 3 modes of operation and you can use any one of them as per your use. A lot depends what you want to do with the data after sampling it.
Thanks for replay,
I'll use Stratix II for sampling,
the pourpes is to store pixels data with high frame rate, VGA size on SDRAM and to compose 6 small VGA frame on one HDMI 1080@60p.
I don't work with Altera, but I think it is called ALTDDIO_IN.
Ok, you want to store this data, so I think you need to convert this to signal from DDR to SDR before feeding them to a FIFO.
Have fun!
