[SOLVED] DC diode HOW to calculate the vpo
Warni
Newbie level 1
Newbie level 1
Hello everyone
Thanks in advance
V_out = V_in - V_ R
V_R = R × I_R.
Hope this helps.
Klaus
Reactions: Warni
    Warni
without an attached load V_Po is +10 V. By applying an load you are creating a voltage divider e.g. for a load with 9 kΩ, your V_Po is +9 V.
greets
The solution suggested by KlausST is even more accurate if you consider the diode's reverse current.
Reactions: Warni
    Warni
