Ogbachi
Junior Member level 1
All,
I am currently working on my final year project of a boost converter. The dc-dc boost converter specifications are as follows:
Input Voltage-12V(can be adjusted)
Output Voltage-24V(can be adjusted)
Output Current-100A(major concern), use of four switch elements connected in parallel to achieve this.
And there is restriction to use basic MOSFET, IGBT and BJT as the switching element.
I found 2SK2266 for the switch element, please, would want to know if this MOSFET can be connected in parallel?
I also have the following questions to ask:
-how do i select my switch driver, capacitor, inductor, diode, and PWA generator?
-how do i get a better circuit to achieve the specification above?
-how do i connect switch elements to achieve higher current?
Please this is my first time of designing boost converter, need your advice.
Thanks...
Thanks...
