Data rate Vs SNR in matlab Help
s.asad114
Junior Member level 1
hyd pak
Im working on Analysis of Cooperative communication in wireless ntws.
i had made a matlab code in which i analysis BER performance (BER Vs SNR) of Co-Op Comm , since Co-Op Comm provide Increased data rate on less SNR as compare to Direct comm so i want to add Data rate VS SNR plot in my work .
im also interested in adding BER Vs Distance Curve , if ANy one can guide me that how i can do it on matlab then please Help me
im waiting
hi
its easy just post ur code down here and i'll try to help u.
hi
thanks Man !
im giving you my code with relative functions file
please guide me to do as i said before...
waiting for Reply
  • Codes + function files.zip
You Simply plot my result but didnt told me How i can Plot Data rate Vs SNR Curve ...
So that mean u r not who programmed this code? However this is the command that u can use to plot ur data Vs SNR
semilogy(SNRdB,bersd,SNRdB,bermrc)
of course i made these program but thing is that im currently plotting Bit Error Rate against SNR.
I want to PLot Data rate Vs SNR.
Do you know any relationship Between BER and Data rate through which i can plot what i wan.
for sake of example, say at BER of 10^-3 data rate is 10kbps & so on
I have the same problem, did find a solution to draw the data rate??
