walters
Advanced Member level 2
What tools are the best to cut PCB traces?
What tool is the best to LIFT up fine pitch pins, they don't break?
What tool is the best to lift up SMT IC pins? so they don't break?
What can I put under an IC pin after I have lifted the pin up so it doesn't short out to the pad
Because when I lift up the IC pin I put a wire on it to re-route the signal so I don't want it to touch the PAD underneath anymore, but I don't know what to put on the pad to not make the pin short out to the pad on the PCB when the IC pin is Lifted? what can i use please?
Do you use a soldering iron to lift up the IC pin? But the IC pin mostly breaks off
