current sensing circuit
pona
Junior Member level 2
Hi, I want to design a circuit which can detect current pulses and give static voltage in accordance with
current passed. For example if a current pulse of 10ms duration passes through my circuit than I want my circuit to give voltage and hold it there. I have tried using sense circuits for dc power supply in which a
sense resistor senses current and an opamp is used to amplify voltage drop across it to a certain value and using capacitor i can hold this value. But i was wondering if there is a special circuit for sensing pulses of current. And is there a method of sensing current which uses a sense resistor but doesnt use an opamp? Any help would be great.
If you want to keep sense resistor voltage drop and power dissipation low, you can't avoid some kind of amplifier.
an alternative solution is to use transistor current mirror
Alex
