diegomaradona
Junior Member level 1
I am not good in electronics so I need your help. I need to pair up two dc sources in one trough two current regulation diodes and each diode must be on different source. I am making colloidal silver and I have two 1n5283 current regulation diodes for current regulation which need to be paired because I need much voltage I can get for this.Higher voltage means faster process of making solution and this type of diodes can handle up to 100 volts so with two of them in pair I will get max. 200 Volts.If I can pair them up like I will show on attached image besides of double voltage on electrodes I will get double current also and I need to have smaller current I can get because smaller current means smaller particles of silver(desirable). So is there a way to divide current after diodes with some parallel circuit and variable resistance in other branch so the current on anode be under 0.2mA constantly?I am making this solution in distilled water so in the beginning of the process resistance of the solution is high and with time resistance drops as water started to mixed with silver particles.
