message4guru
Junior Member level 2
I designed a Lab power supply with LM723(for 0-30V @ 5Ampere),Initially I limited the current at .65 ampere(I limit=o.65V/1 ohm). But the problem is ,the IC is not performing the current limiting operation, eventhough it had potential difference is 5V across its base to emitter transistor which does this current limiting function.
What could be the problem?
1)is with current sense resistor precision?
2) is it with Base emitter junction breakdown in transistor? Because of 5V across it?
Totally confused . Help me in this regard...
