Creating Spacer Using Solder Paste
phaas
Newbie level 2
North Carolina
I am needing a 14 mil spacer to be placed under a thru-hole part. As this is a low volume product I was thinking of trying to create a spacer using a SMT pad and solder paste with no part on it during heating. Once the paste melts it should create a dome. My question is how to calculate the size of pad needed to create a 14 mil spacer? Is it even possible? I believe the stencil is 5 mil, I am confirming this right now. If this cheap way does not work I will have to pay the extra cost to have the assembler added tape under the part before soldering.
Interesting problem. Below is my proposed solution.
Assumption:
- the pad is square shaped with the base length of a
- solder paste solid content is 90%
- liquid solder surface tension is 400N/m (in reality it is somewhere between 350 and 500 N/m)
First liquid solder will form a puddle on the pad surface whose maximal hight can be calculated from the following formula
hmax = (sqrroot(2*gamma*(1 - cos(theta)))/(g*psi) where
psi - is the density of the liquid, approximately 8000kg/m^3
g - is the acceleration due to gravity ~10m^2/s
gamma - is the surface tension, 400N/m
theta - is the liquid surface contact angle; in our case theta -> 0 when a -> inf.
Next I am going to approximate the shape of the dome with a square pyramid, with base length a and height h.
Volume of such pyramid
V = 1/3*a^2*h
The volume of solder deposited on the pad
Vs = 0.9 * a^2 *hs
where hs - is the height of the stencil
Obviously Vs and V are equal. We can then calculate the height of the pyramid.
h = 2.7*hs
assuming that hs=5mils
h = 14mils
It seems like it does not matter how big or small the pad is. The height of the dome (pyramid) only depends on the height of a stencil used.
Not so much....
if we now go back to our first equation, the one with max height of a liquid on a surface. When the pad gets bigger its base length a gets bigger in relation to its height h. This means that the surface angle theta -> 0 and cos(theta) -> 1 and therefore hmax -> 0.
So we need the hmax to be just a bit bigger than 14 mils, lets say 16mils, which can be rounded down to 0.4mm = 0.0004m
cos(theta) = 1 - ((hmax*g*psi)^2)/(2*gamma)
in our case
cos(theta) = 0.32
we also know that
cos(theta) = (0.5 * a)/sqrroot(0.25*a^2 + hmax^2)
so
a = cos(theta)*hmax/(0.25 - 0.25*(cos(theta))^2)
hmax = 16 mils = 0.0004m
cos(theta) = 0.32
what we get is
a = 0.00048m = 18.8mils
So to sum up - you can use any square shaped pad with its base length up to 18.8mils.
Hopefully someone will challenge my calculations :)
Piotr,
You had me up to cos(theta) = 1 - ((hmax *g*psi)^2)/(2*gamma). I can not get 0.32, I am getting -0.28? After that nothing is seeming to work. I not saying it is wrong, just I am getting lost.
Thanks,
Paul
Yeah I think I see the error.
it should be
hmax = sqrroot((2*gamma*(1 - cos(theta)))/(g*psi))
so
cos(theta) = 1 - (h^2 * g * psi)/(2*gamma)
cos(theta) = 1 - 0.000016 = ~1
theta =~0
That means that the size of the pad should not matter... hmmm I wonder if this is the case
