Go to Silicon Integration Initiative (Si2), http://www.si2.org/
LEF DEF Format Specification **broken link removed**
hi,
what you want is a whole flow.
you have to p&r your design and generate gds, and then suing abstract from c@dence to extract lef file.
or you can use encounter or astro to extract lef,but accuracy is a matter.
hi linuxluo,
yes, i agree with you about creating lef. this is almost like backtracking. What i was thinking was, along with the netlist, if it has memories, then, a lef will be given so that the memory can be made into a blackbox in the netlist during the semi-custom flow. my question is:
do you take the memory's netlist alone through the complete flow and generate the lef file?
in this way, can we generate the physical information of the memory and create a blackbox that can be used along with other netlists ??
Hope i'm clear. Incase if i'm not please let me know.
