It depends on your network connection between your home and company.
I used VPN to login remote desktop in my office. And from that box I login to the design server.
In this case only graphic data and some control data are transfered on the network. It is smaller compared to the huge simulated waveform data.
My suggestion is that you use remote desktop to run xwindws server not your local desktop.
You can improve the speed further by using VNC not xwindows.
2. what kind of remote desktop program do you use? the one in xp or other commercial program, could you recommmend one for me?
3. prevously i use Exceed to connect from home, but speed is pretty slow, but exceed provides the best graphical interface , vnc dose improve the speed significantly, but not convenient to use, which vnc program do you use? could you recommmend one?
1. I am using ADSL with similar speed. I think it should be fast enough.
2. I use the remode desktop program in XP to connect to Win2003 Server.
3. For VNC, I am using RealVNC 4.
i have tried xp's remote desktop before, but not successful, i have install TCP/IP protocol, and also enble the sharing service, what else do i have to do? thanks again.
The usage of RealVNC is the same as all other VNC variants. You just need start a VNC server on your workstation and set the password. This server can be started under normal user account.
RealVNC is more securer than other VNC variants. But you can increase the security by using SSH tunneling feature and use -localhost option to limit only this workstation can access this VNC server. Nowadays, the Linux distributions already have VNC installed. If your workstation does not have it, you can copy it in your home dir.
It is very easy. You can simply install it and try it.
previouly, i use vpn to setup connection to school, and use SSH and Exceed to acess cadence, exceed is very slow that, i have to shift to vnc, but vnc is just not graphical friendly (i can not expand the window to amolst full screen), that is why i ask u question in vnc, by the way, all this is run on xp.
A couple of clear advantages of VNC is that you can access the same session from any location that you have vnc client installed. I can start a simulation on the vnc session from my office, shut down the client, drive home, start a new client accessing the same server session and check the simulation. Try that with exceed.
