sareene
Junior Member level 1
verilog corner case
Hi Everyone, The following is a small verilog code which below models a flip-flop with asynchronous set/reset logic (active low). The model synthesizes correctly, but there is a corner case where simulation results are incorrect. What is the corner case?
always_ff @( posedge clk
or negedge rst_n // active-low reset
or negedge set_n // active-low set
if (!rst_n) // reset has priority over set
q_out <= '0; // reset all bits to zero
else if (!set_n)
q_out <= '1; // set all bits to one
else
q_out <= data_in; // d input assignment
else if (!set_n)
else
