Core losses in LLC converter resonant inductor?
cupoftea
Advanced Member level 5
Doing 4kW Full Bridge LLC converter resonant inductor of 24.9uH.
ETD59 with 1mm gap for AL=508.
(7 turns of 3 strands of TEX-ELZ 7/0.3mm)
100kHz.
Irms is 11.9A
Ipk is 17.2A. (+/-17.2A)
Bpk is 0.166T. Will the core losses be too excessive?
There are fans but not mounted right next to this inductor.
I can reduce the Bpk to 0.142T by using the 1.5mm gap ETD59 (AL = 381) and winding 8 turns.....but i thought the bigger gap will give more fringing flux problems?
--- Updated ---
On the same type of subject...
We need ETD59 in N87 material ungapped.
However, ungapped is only available in 3C90
At 100kHz and 200mT, N87 is at 350kW/m^3, whereas 3C90 is at 450kW/m^3
That would mean the 3C90 ETD59 core dissipating 23W, but the N87 ETD59 dissipating 17.9W.
Would you say, with those dissipations, that even with a fan right on it, either 3C90 or N87 would go over the Curie temperature, and the transformer coils all go short circuit?
3C90
N87
