hweontey
I am new beginner in PIC microcontroller. I use PIC16F877A and Hi-Tech PICC LITE Compiler (C compiler). I already wrote C codes to get analogue voltage from GP2D12 distance sensor. But, i tried many times to convert it into distance value based on datasheet. I still can't get it. I NEED some help. I hope everyone can share experience and idea with me. The C codes as shown below. Thanks.
Added after 3 minutes:
My C codes:
//==================inckude=================================
#include<pic.h>
//===============configuration==============================
__CONFIG (0x3F32);
//===============define IO port=============================
#define lcd PORTB
#define RS RA2
#define E RA5
#define CHANNEL0 0b10000001 // AN0 sensor0
//==============FUNCTION PTOTOTYPE=========================
void e_pulse(void);//
void delay(unsigned short i);//
void send_char(unsigned char data);//
void send_config(unsigned char data);//
void lcd_goto(unsigned char data);//
void lcd_clr(void);//
void dis_num(unsigned long data);
void read_adc(void);
unsigned short read_temp(void);
//====================MAIN================================
unsigned short result;
unsigned short temp;
void main(void)
ADRESH=0; //clear A/D result
ADRESL=0; //clear A/D result
//setting ADCON1 Register
ADCON1=0b11000101; // A/D result right justified,
// configure RA2 and RA5 as digital I/O
TRISA=0b11011011; //configure PORTA I/O direction
TRISB=0b00000000; //configure PORTB as output
TRISC=0b00000000; //configure PORTC as output
PORTA=0;
PORTC=0;
while(1)
send_config(0b00000001); //clear display at lcd
send_config(0b00000010); //Lcd Return to home
send_config(0b00000110); //entry mode-cursor increase 1
send_config(0b00001100); //diplay on, cursor off and cursor blink off
send_config(0b00111000); //function set
lcd_goto(0); //cursor start from beginning
send_char('D');
send_char('I');
send_char('S');
send_char('T');
send_char('A');
send_char('N');
send_char('C');
send_char('E');
send_char('=');
while(1) //infinity loop
//sensor A
ADCON0=CHANNEL0; //CHANNEL0=0b10000001
lcd_goto(9);
read_adc();
temp=read_temp();//***Question: How to convert analogue voltage from sensor to distance in cm based on GP2D12 sensor??
dis_num(temp/10);
send_char('.');
dis_num(temp%10);
send_char('C');
send_char('M');
delay(2000);
//==================subroutine LCD setting ==========================
RS=0;
lcd=data;
delay(500);
e_pulse();
void e_pulse(void)
E=1;
delay(500);
E=0;
delay(500);
RS=1;
lcd=data;
delay(500);
e_pulse();
if(data<16)
send_config(0x80+data);
else
data=data-20;
send_config(0xc0+data);
void lcd_clr(void)
RS=0;
send_config(0x01);
delay(600);
unsigned char hundred_thousand;
unsigned char ten_thousand;
unsigned char thousand;
unsigned char hundred;
unsigned char tenth;
hundred_thousand = data/100000;
data = data % 100000;
ten_thousand = data/10000;
data = data % 10000;
thousand = data / 1000;
data = data % 1000;
hundred = data / 100;
data = data % 100;
tenth = data / 10;
data = data % 10;
if(hundred_thousand>0)
send_char(hundred_thousand + 0x30); //0x30 added to become ASCII code
send_char(ten_thousand + 0x30);
send_char(thousand + 0x30);
send_char(hundred + 0x30);
send_char(tenth + 0x30);
send_char(data + 0x30);
else if(ten_thousand>0)
send_char(ten_thousand + 0x30); //0x30 added to become ASCII code
else if(thousand>0)
send_char(thousand + 0x30); //0x30 added to become ASCII code
else if(hundred>0)
send_char(hundred + 0x30); //0x30 added to become ASCII code
else if(tenth>0)
send_char(tenth + 0x30); //0x30 added to become ASCII code
else send_char(data + 0x30); //0x30 added to become ASCII code
//==================subroutine ADC=========================
void read_adc(void)
unsigned short i;
unsigned long result_temp=0;
for(i=2000;i>0;i-=1) //looping 2000 times for getting average value
ADGO = 1; //ADGO is the bit 2 of the ADCON0 register
while(ADGO==1); //ADC start, ADGO=0 after finish ADC progress
result=ADRESH;
result=result<<8; //shift to left for 8 bit
result=result|ADRESL; //10 bit result from ADC
result_temp+=result;
result = result_temp/2000; //getting average value
temp=result;
return temp;
//==================subroutine DELAY==========================
for(;i>0;i--);
My C codes:
#include<pic.h>
__CONFIG (0x3F32);
#define lcd PORTB
#define RS RA2
#define E RA5
void main(void)
PORTA=0;
PORTC=0;
while(1)
send_char('D');
send_char('I');
send_char('S');
send_char('T');
send_char('A');
send_char('N');
send_char('C');
send_char('E');
send_char('=');
//sensor A
lcd_goto(9);
read_adc();
dis_num(temp/10);
send_char('.');
dis_num(temp%10);
send_char('C');
send_char('M');
delay(2000);
RS=0;
lcd=data;
delay(500);
e_pulse();
void e_pulse(void)
E=1;
delay(500);
E=0;
delay(500);
RS=1;
lcd=data;
delay(500);
e_pulse();
if(data<16)
else
data=data-20;
void lcd_clr(void)
RS=0;
send_config(0x01);
delay(600);
data = data % 1000;
data = data % 100;
tenth = data / 10;
data = data % 10;
else if(thousand>0)
else if(hundred>0)
else if(tenth>0)
void read_adc(void)
unsigned short i;
result=ADRESH;
temp=result;
return temp;
for(;i>0;i--);
