controling `timescale from the testbench
cyboman
Member level 4
USA
does anybody know if there is a way to control the `timescale values from the testbench
all the designs i have done so far (i'm new to digital design) have a `timescale 1ns/1ps in them. my testbenches have the same `timescale in it. i noticed that when i increase the `timescale to `timescale 10ns/1ns my simulations run faster (at least the behavioral ones). but in order to change the timescale i need to do it manually in the testbench and all the modules that are in the testbench
example:
say i have the following hierarchy:
testbench -> dut -> module3_u3
                 -> module2_u2
                 -> module1_u1
                 -> module0_u0
in order to change the timescale i need manually go to testbench and change the timescale, manually go to dut and change the timescale, go to module3, module2 etc and change the timescale in every module that is instantiated in the dut. does anybody know a way to pass a timescale value to the testbench, say like a parameter. this value will passed down to every subsequent module that is being simulated.
so it would probably look like this:
testbench #(.unit_step(10), precision(1))
meaning that dut will have `timescale 10ns / 1ns, module0 will have `timescale 10ns / 1ns, module1 will have `timescale 10ns/ 1ns etc.
any help is appreciated
$timeformat
timeformat_task ::=
$timeformat [ ( units_number , precision_number , suffix_string , minimum_field_width ) ] ;
The $timeformat system task performs the following two functions:
— It specifies how the %t format specification reports time information for the $write, $display,
$strobe, $monitor, $fwrite, $fdisplay, $fstrobe, and $fmonitor group of system tasks.
— It specifies the time unit for delays entered interactively.
The $timeformat system task performs the following two operations:
— It sets the time unit for all later-entered delays entered interactively.
— It sets the time unit, precision number, suffix string, and minimum field width for all %t formats
specified in all modules that follow in the source description until another $timeformat system task
is invoked.
Refer in
HTH
    cyboman
shitansh,
thanks for the help
