namit
Junior Member level 3
I having few problems with this.
So i have messed around a bit with compiling parallel port programs trying to set ports to 1 and 0. But not quite sure if its working.
1. I put multimeter on one of the top pins and on one of the groud pins and 5.5v are coming out of it. Should this be the case?
2. Then i have the multimerter still on and run the software i have compiled and the voltage does not change. Whats with this?
3. How i expect parallel ports should work is when they are off they should show 0v and when they are on they should show 5v?
