Contacts & Vias used in Layout
SP24
Junior Member level 3
Why do the Vias and Contacts we use in our Layouts square in shape(not rectangular)?
I guess you have seen the feature to change it.. you can change ir. its your option... :)
They usually are square, but they can be rectangular, too. Important is that they are unique (all the same size). Contacts and vias are the most numerous data structures in a layout, so their OPC data prep CPU time has to be minimized, hence this uniqueness requirement, s. e.g. this thread.
Reactions: SP24
    SP24
It's about process control. You can tune an etch process for
one feature geometry much better than you can when it has
to cover a range - especially when the most-used is at the
barely-capable end of the tool set, you may need to favor it
to exclusion of other sizes (which otherwise would tend to
"blow out" larger than as-drawn, and any contact-defined
device attributes possibly be uncontrolled, or min-contact-
consistent overlap rules violated, or whatever).
