garg29
Advanced Member level 1
constant current source
Hi friends,
I have to design a project in which i have to generate constant current & this constant current should be variable through microcontroller, but before interfacing with microcontroller i'm trying to create a circuit for constant current source only. I'm trying to use LM2576 for the same. I found many circuits on net here also on eda but none of them is working. I'm using this constant current for some electrolysis process. when i use normal opamp-transsistor based circuit (as shown in the disgram) it works fine but there is Huge Heat dissipation due to this reason i want to shift to this regulator.
please see that attachments.
I'm unable to find the problem please help me.
Thanks.
With best regards.
Hi friends,
Thanks.
With best regards.
