Connecting a piezoelectric transducer
Eight
Member level 2
Hello.
I've been looking at some piezo elements with their driving circuits online, and I'm puzzled by a few things. A piezo element is supposedly a capacitive load, and, according to some forum posts, the polarity doesn't really matter. The manufacturers normally specify their rated peak-to-peak voltage. Now, suppose I have a driving circuit, which generates a 16Vp-p 50% duty cycle square waveform at 1 kHz. Assuming the piezo transducer is rated for this voltage, I'd like to feed the given waveform to the element, but I'm mystified how to correctly connect the device.
Should I connect one end to the driving circuit and the other to ground? Or should I create a low-impedance virtual ground at +8V in place of the normal 0V ground (or rather use a square wave generator i.e. a full-bridge that generates output from -8 to +8V in respect to the ground rather than 0V to 16V range)? See the attached picture. In both cases the element will be driven by a 16Vp-p range, but the mean voltage will shifted by 8V down to ground, allowing negative voltage to appear on the piezo element.
What is the difference in performance when driving a piezoelectric transducer in the two given ways?
There's no difference as long as the applied voltage is considerably below the maximal permitted DC voltage level. Otherwise depolarisation of the piezo can happen.
A piezo transducer strongly resonates at a frequency between 3kHz and 6kHz. If you feed it with a 1kHz squarewave then most of its output will be at its odd harmonic number of 3kHz or 5kHz.
