Connect PC & PIC using Bluetooth
nicko-391
Sri Lanka
I want to connect PIC(18f or 16f) with PC using Bluetooth.I never used Bluetooth module.How can I start this? Which Bluetooth module is suitable for this?
Please Help.
you can use some serial bluetooth module for connecting to the PIC, and some USB device for the PC
u need only a program that will work on the PC and recognize the PIC ..
I have used a Bluegiga WT12 module with a PIC24FJ64GB002 for a similar project
The PIC24FJ64GB002 comes in a 28 SDIP package so makes it easy to build a simple of PCB or even a breadboard
Microchip USB stack available fee from
**broken link removed** also seems to be a nice solution. You just communicate with your PC through the UART interface of your PIC, which is very easy. It has a standard pitched connector so you can just plug the module onto a breadboard or solderboard.
