Confused by 555 pinout...
itsallgood
Member level 2
Hi all,
I'm confused by 555 timers when looking at circuit diagrams.
If the 555 is a rectangle with 4 pins on one side, and 4 on the other. And they are numbered 1 to 8 anti-clockwise from the notch.
How do you use circuit projects where the chip is shown square, and the legs are in no order?
A 555 timer:
A circuit:
The chip has pins all the way round, and the order is wrong???
I'm looking at this page here:
Any help would be great.
Cheers.
A schematic diagram can have any pin arrangement that is physically possible ..
I don’t think when your friends arrive to your place they all park their cars in the same sequence at all times ..
Rgds,
IanP
The schematic has nothing to do with the physical description of the chip. You have to be a little careful, as semiconductor chips are often available in several very different package styles. You have to make sure you are connecting the right pin to the right function on your project.
In the case of the LM555, you are in luck, though. They all use a 8 pin rectangular package, where pin 1 is ALWAYS the one next to the small dot, or if there is not small dot, the pin to the left of the little horseshoe indentation when viewing the chip from the top.
Drawing a chip with the pins in a non-sequential order is done simply to make the circuit diagram easier to follow.
Keith
Just make sure the pin number is correct accordingly to the circuit example.
Don't worry about where the leg are. They are just picture.
MODERATOR - SIGNATURE LINKS ARE NOT ALLOWED
    itsallgood
