Common ques asked regarding CTS in the interviews?
fail1
Junior Member level 3
How do u balance the clocks during CTS?
How do u start answering this question & what all topics we should cover while answering this question?
Thanks
Kumar
Clock balancing is even distribution of load on the different clock paths so that skew will be minimum in the design. There are several techniques through which you can balance the skew such as
1. Gate/Buffer Sizing--sizes up/down buffers/gates to improve both skew and insertion delay( In this method the clock tree structure will not be modified)
2. Gate/Buffer relocation--The position of buffer will be adjusted so that skew/insertion delay is reduced. The hierarchy of the clock tree will remain intact in this method.
3.delay insertion--Delay is inserted for shortest paths(Not advisable because this can lead to other timing violations)
Hope this explains...
