biolycans
Member level 2
My question is related to the CMRR (common mode rejection ratio).
1) First I connected a voltage supply with an AC signal of 1V amplitude to the not inverting input of the opamp. The inverting input I connected to ground. Then I did a dc sweep to find the offset, then I included this offset to this configuration. Then I did a AC sweep between 1 Hz to 10 MHz. This plot represents the differential gain in dB versus frequency Mhz.
2) Then I connected both inputs together to a voltage supply AC 1V amplitude. I included the offset I measured before. Then I did an AC sweep between 1Hz to 10 Mhz. This plot represents the common mode gain dB versus frequency Mhz.
3) Then I chose for example 10 Hz (I did this with many frequencies), I chose for this frequency the gain (differential gain in dB and the common mode gain in dB). I did the subtraction between both. The result is the CMRR in dB.
Is this correct ?
Regards,
JC
Is this correct ?
Regards,
JC
