pavelni
Junior Member level 1
common centroid layout of analog transistors
Hello all!
I've got the next problem:
I'm designign the LNA for RF (about 1GHz). I have one issue with designing of layout of the differential pair.
There is a usual way of design - using of common-centroid techique for differential pair. But instead of common centroid I want to move each transistor from each other and do not mix parts of them.
Could you please tell me if there any advantages and disadvantages between this two techniques?
How can I evaluate influence of the transistors on each other in both cases?
Could you please advise me some books about this?
Thanks in advance![/img]
Hello all!
