I’ve never done PIC before, but I think that if you have even the slightest idea about what uC, SPI, ASM and C means, besides being letters in the alphabet, you’d be able to “write” (read “copy”) all the code you need in no time.
Microchip’s web site is bursting with application notes and code snippets, so I wonder why won’t you consume 0.7 of you own calories and look there for an SPI example (which is btw. the way of interfacing the 2 chips you mentioned).
Because I don’t want to believe you really are so lazy, I will assume that your finger hurts and you’d like to limit the number of mouse clicks to a minimum. Click once here then: **broken link removed**
I’m afraid you’d need two more clicks to download the source code.
If you substitute the EEPROM in the example with your MCP23S17 (and maybe read its datasheet…) you’re all done without breaking a sweat!
I think it will be good to try out some coding on your own.
When you encounter some technical issue,
this is a good place for you to ask and learn.
There are many many experience friends here to help us.
In fact if you need the code, there are many
site which source is available. From microchip perhaps.
If you come to forum, my mentality is that you really
want to learn something from here.
A source code example would be good to start with,
but most of the time I will normally use it as it is, and didn't learn anything.
Give it a try on SPI , you will learn more which is a useful experience
for other area, not only in SPI (although you are doing SPI).
I Have tried to interface PIC16F877A with MCP23S17 in MPLAB, but still i am not getting the result. I have specified my code please check it out below and tell me to do futher process.
Read up on the datasheet to enable that you have all the bits
correctly enabled. Understand what each bit is trying to do.
The datasheet is pretty well written.
Follow the step by step guide should do.
Perhaps you can start writing a write() function.
Check if there is any output signal from the controller pin,
after the write is issued.
If not, ensure that you have set the bits correctly.
Make sure you can write before your read,
because it is easier to write.
