Clock Transition vs Clock Skew?
RGR
Junior Member level 2
Hello Every one,
can any one explain about
Which is more important Clock Transition or Clock Skew?
Thank you
RGR
What do you mean by "more important"? Both are different things which can happen simultaneously in a logic circuit.
clock skew is the difference of time between the flop with the minimum latency from the source clock, and the flop with the maximum latency from the source clock.
clock transition is the transition on all clock nets.
The first is just an quality indication.
The second is a DRV at least from the liberty or over constraint by the designer.
