clock multiplexer problem - help needed
bigdog
Junior Member level 2
clock multiplexer
I have two input clocks, CLKA and CLKB.
They go to a multiplexer directly from input port then generate a new clock CLK_SYS as the system clock of the whole circuit, but the select signal of the clock multiplexer comes from the CLK_SYS domain and its value is not a constant.
So, how should I define the clocks of this circuit?
Note: I use Synopsys design complier.
Thanks!
Re: clock multiplexer
bigdog said:
Thanks!
You could use the max frequency(in your design) clock to synthesis.
If I do so, how do I to do the timing analysis with PT, should I set case analysis since I have a multiplexer on the clock path?
Yep, you could use the case analysis for safety
clock multiplexer
Ok, thanks, I'll try that.
clock multiplexer
I don't think you need to. STA tools know to analyze both clocks. You'll get 2 paths.
bigdog said:
Thanks!
For this you have to use No-Glitch mux to switch clock attached file is application of clock multiplexer.
Also verilog file code of No-Glitch Mux is available from
I have did this before long time and i also used Synopsys design complier.
HTH
Shitansh Vaghela
Hi Shitansh,
I know it is very old thread, But I need some help on this as you tested on DC.
I am using the same code which you mentioned for my design. I am not able to perform STA properly. I want to do power analysis for each clock and at the same time want to check how many registers clocked during case_analysis, so I am using the set_case_analysis but it is not working, means if I set select pin as 1 or 0 in both the case both the clocks are going to all registers. Have you experienced this issues, do I need to set any other constraints please let me know.
Anybody who knows anything about this, then please give some suggestion.
Thanks for reading this post.
