Clarifications in IAR IDE 6.21 - LM3S9B96
Chinnathambi
Newbie level 3
We need some clarifications in IAR IDE 6.21 (lm3s9b96),
1)How to enable the option for Profiling as we could not see any plugins in Project options (But this option is available in version 5.41)
2)We are facing issues when we try to compile the given example applications (C:\Program Files\IAR Systems\Embedded Workbench 6.0 Evaluation\arm\examples\TexasInstruments\Stellaris\boards\dk-lm3s9b96\qs-checkout) copied to some other directory (ex: D:/qs-checkout). How to remove/modify the dependencies if we want to use these codes for custom application.
Could you please clarify us on the above queries?
Thanks in advance,
Regards,
Chinnathambi
Hai,
We are using IAR IDE 6.21 (lm3s9b96) licensed version.
As stated in your mail, we referred \arm\doc\EWARM_DebuggingGuide.ENU.pdf file for profiling.
It is mentioned like there is no profiling support for TI Stellaris FTDI (Table II - C-SPY driver profiling support - Page 213)
Kindly clarify, Is there any alternate option available to enable profiling in TI Stellaris FTDI debugger ?
Regards,
Chinnathambi .M
