WhyWhy
Member level 4
Hi guys,
Actually i wants to know my concept is correct or not.
1) Starting the 5V will supply to the IR Transmitter because of the resistance is the lowest among R1,R2,VR1 and VR2. 2) Then the IR receiver will get the voltage and pass it to the inverter.
3) The Output of the LM324 is depend on the comparison between Voltage of VR1(10kohm) and IR Receiver.
Condition:
If Voltage VR1 is lower than IR Receiver then the Output of LM324 will equal to low,whereas Voltage VR1 is higher than IR Receiver then the Output of LM324 will equal to high.
Question:
1) Did the R1,R2,VR1 and VR2 just limit the current only?
2) what is the voltage of VR1 (10Kohm)?
3) Why i need the VR2(4.7Kohm)?
4) Can i just connect the Comparator Pin 7 to microcontroller?
Thanks for help :razz:
![Infrared (IR) sensor.gif Infrared (IR) sensor.gif](https://www.edaboard.com/data/attachments/38/38036-6384c299a70979aa49ea8110c18017b5.jpg)
Condition:
Question:
