choosing regulators for power up FPGA (xilinx spartan3)
dilan2005
Member level 4
xilinx spartan 3
hi all
i need some thougts on choosing regulators to power up spartan3 500E fpga.
i decided to use following LDO linear regulators.
LD1117ADT12TR 1.2v
LD1117DT25CTR h
LD1117V33
is it necessary use buck type regulators! whrere using L and C to filter and
get out voltages.
please share your experience with me!
Thanks!
rgds
dilan
voltage regulator for spartan3 fpga
thanks echo47
i also used above as the reference to order my parts
is thee any special requirement other than LDO to power up the FPGA
Thanks a lot
rgds
dilan
input voltage xilinx spartan 3 fpga
It's worthwhile reading these Xilinx documents:
"Spartan-3 FPGA Family Complete Data Sheet" (DS099), section "Functional Description", sub-section "Powering Spartan-3 FPGAs".
"Spartan-3 Generation FPGA User Guide" (UG331), chapter "Powering Spartan-3 Generation FPGAs".
Many designers use LDO regulators when the project's available input voltage is too low for ordinary regulators. However, LDO isn't a requirement if your input voltage is high enough for an ordinary regulator. Of course, the efficiency of a linear regulator decreases as you increase the input voltage. Switching regulators are generally more efficient but more complex.
    dilan2005
spartan power regulator forum
Hi Dear Echo47.
I want to design power supply for Virtex 2 Board (XC2V40) but i have some ambigoues in a few aspects.
I want to apply switching regulators for their high effficiency and their potents to inject enough high current during power-on time.
After the power-on duration, the sysstem will not consume such high currents. then in acording to the switchig regulators specification that has been mentioned in its datasheet, in low level output current, The switching regulators efficiency would be degraded and we loos our goul to achive low dissipation and high efficiency.
What is your opinion about this issue?
Is there any idea to design this power provider part of this board more efficiently?
Thanks in advance
Alireza
