checking not conneced tracka
m2babaey
Junior Member level 2
Hi
Sometimes I face small tracks forgotten in the designed PCB
How can I check that all tracks are connected in Altium 2009?
Thanks
Go to report/board information/OK/select required parameter by checking(for your need check on routing information)/OK.
This gives you the completion of routing.
if you want to check the which track is not connected then run DRC.
Run Design rule check with unrouted nets enabled.A report will be generated and in that u will find the unrouted pins list.
