changes in Dynamic resistance of Schottky diode
bhatt_190487
When the Rf power signal is applied to the Schottky diode,the dynamic resistance changes. It sometimes increases and then again decreases. I want to know why the dynamic resistance changes on increasing the RF power supply? Please help me. What is the relation of Power signal with the dynamic resistance change. the dynamic resistance depends on Dc current or Ac current?
Thank you in advance.
It depends on the bias (DC) current.
Look into datasheet. There you may find a U-I chart where you can find our dynamic resistance.
Read the "definition" of dynamic resistance.
Thank you for the reply.
The resistance decreases as the current increases...as per the graph.
Can you help me how can i relate the changes of schottky diode dynamic resistance with the increasing RF power level at low bias voltage and high bias voltage?
Hiw can we help you?
We don't have diode type, nor datasheet, nor do we know the values of the currents...
In common :
Find the point where the bias current meets the graph. Draw a tangent at this point to the graph.
Find the rate dU/dI. This is the dynamic resistance.
