[SOLVED] CDMA peak to average power ration (PAPR) problem
Aya2002
Iraq
hello friends,
I need to know if there is a PAPR in CDMA system, please prove that
thanks
Hello Montadar my friend, a post from you after a long time. You must be busy.
Here is what I know about the PAPR problem with DS-CDMA.
As you know we have quadrature modulation schemes such as QAM being used in most communication systems these days, so in those systems, it can happen that the I channel and the Q channel can combine constructively to produce a signal which is of a higher value of power as compared to average power of cdma symbols.
This, I think leads to a higher value of PAPR and in order to remove this, both channel are randomized using two different scrambling sequences (CDMA2000, I think)
I think you get the idea, but please verify this as I am kind of rusty on this matter.
Reactions: Aya2002
    Aya2002
It's about 3.2 db for WCDMA. I am not as familar with CDMA bandwidths but it is probably similar.
I assume the question is related to PA linearity requirements.
If you like (W)CDMA peak to average, you will really love 4G OFDM.
(this is for handset, not basestation)
Reactions: Aya2002
    Aya2002
does any body have other comments but with prove?
thank you
Here's a couple of papers, I cannot remember where I retreived them, dealing with PAPR reduction in MC-CDMA, there is an indepth discussion and analysis of PAPR in MC-CDMA systems.
Hope these help in your endeavor!
  • PAPR_Reduction_MC-CDMA.pdf
  • HPL-PAPR.pdf
Reactions: Aya2002
    Aya2002
